Common Flatbed Trailer Brake Issues and How to Fix Them?
38
I’ve been having some trouble with my flatbed trailer brakes and wanted to see if others have run into the same issues. What are the most common brake problems you’ve dealt with, electric or hydraulic, and how did you fix them? Any tips on quick checks or maintenance routines would be a big help.
Hey Richard, yeah I’ve run into a few issues over time, corroded wiring on electric brakes is a big one, especially after wet conditions. I usually start by checking connections and making sure the ground is solid. On hydraulic setups, leaks or air in the lines have given me trouble before. A quick brake bleed and fluid top-off usually does the trick. Regular inspections save a lot of headaches down the road!
Definitely been there, corroded wiring and weak grounds have caused me all kinds of brake headaches. I’ve learned to always check the connections and breakaway switch first before diving deeper!
biggest culprits I’ve seen are corroded grounds,
worn magnets on electric brakes, and air in hydraulic lines
90% of flatbed brake issues trace back to those.
Regularly clean connections, bleed lines, and check for uneven pad wear to stay ahead of it
Appreciate all the feedback, guys! Sounds like bad grounds and corroded wiring are the repeat offenders here-definitely going to start there. Might even add a regular brake check to my monthly maintenance list just to stay ahead of it. Thanks again
