Common Flatbed Trailer Brake Issues and How to Fix Them?
34
I’ve been having some trouble with my flatbed trailer brakes and wanted to see if others have run into the same issues. What are the most common brake problems you’ve dealt with, electric or hydraulic, and how did you fix them? Any tips on quick checks or maintenance routines would be a big help.
Hey Richard, yeah I’ve run into a few issues over time, corroded wiring on electric brakes is a big one, especially after wet conditions. I usually start by checking connections and making sure the ground is solid. On hydraulic setups, leaks or air in the lines have given me trouble before. A quick brake bleed and fluid top-off usually does the trick. Regular inspections save a lot of headaches down the road!
Definitely been there, corroded wiring and weak grounds have caused me all kinds of brake headaches. I’ve learned to always check the connections and breakaway switch first before diving deeper!
