Why won't my Caterpillar D9G move after a transmission oil change, and could the priority valve be the cause?
34
I recently changed the transmission oil on my Caterpillar D9G, and now the machine won't move at all. Before the oil change, it was operating normally. While researching the issue, I found a similar case involving a D9H where the problem was traced to a dirty priority valve and a faulty pressure control valve. Before I start replacing parts, I'm hoping to get some advice from others who have worked on these older Caterpillar dozers. Could a stuck priority valve, pressure control valve, or loss of transmission pressure cause this issue after a fluid change? Any troubleshooting tips or experience with a D9G transmission not moving after service would be greatly appreciated.
I'd check transmission pressure first before replacing parts. Since it stopped moving right after the oil change, I'd suspect low oil level, wrong oil, a suction leak, or the pump losing prime before blaming the priority or pressure control valves.
