Why do some gears on a Caterpillar 140H work intermittently while others shift to neutral?
Elixer G
15
I'm having a strange transmission issue with my Caterpillar 140H and hoping someone here has dealt with something similar. 1st gear works every time, and 5th and 8th usually work, but sometimes I have to shift back to park first before they engage properly. 2nd gear is the biggest problem because sometimes it bumps and immediately goes back to neutral.
Had almost the same issue on a 140H before, turned out to be a transmission solenoid and wiring problem causing random neutral drops between gears.
