When you perform lifts in rough terrain forklifts, the transmission should be in?
philipBrown
22
Hi everyone,
When operating a rough terrain forklift, should the transmission be in neutral, forward, or reverse while performing lifts? Want to make sure I’m doing it right for safety and stability! Looking forward to
Good question! When lifting, you’ll want the transmission in neutral with the parking brake engaged to keep everything stable. Keeping it in gear while lifting can make things a little sketchy, especially on uneven ground. Ever had one start rolling on you mid-lift? Not fun!
Yeah, always go with neutral and parking brake on when lifting, adds way more stability, especially on uneven terrain. Safety first!
yep, neutral with the brake on is the way to go it helps lock things down, especially when the grounds not exactly level.
I always stick with neutral and the parking brake engaged when lifting. On rough terrain, a little extra stability goes a long way, especially when you're handling heavier loads on uneven ground.
