What would you check if a CASE CX130C monitor randomly turns off, switches screens, or changes to a different language?
IamBruce_Driver
Active member
161
When your CASE monitor starts acting up, flipping screens or switching to Japanese, it's usually a "communication" problem, not a ghost. Think of it like a loose phone charger; when the connection blinks, the system resets to its original factory settings.
Here's what to check:
  • Loose Plugs: Wiggle the wires behind the screen. If the plug is loose or dirty, the monitor loses its "memory" and resets.
  • Bad Grounds: A rusty or loose ground wire is the #1 cause of electronic glitches. Make sure the metal-to-metal connections are clean and tight.
  • Battery Power: If your battery or alternator is weak, the screen might not get enough juice to stay on the right setting.
Most of the time, a quick clean of the plugs and tightening a few bolts fixes the "possession."
Yeah, I've seen this kind of thing happen before. Most of the time, it's not the monitor itself going bad. It's usually some simple electrical issue.
The guide on troubleshooting a CASE CX130C Excavator monitor is very helpful and practical. It clearly explains what to check when the screen randomly turns off or changes language, making maintenance much easier. 👍
On a CASE CX130C, I would first check the power supply and wiring to the monitor. Loose connectors or low voltage can cause random shutdowns or screen changes.
Then check the buttons or keypad in case one is stuck, which could switch screens or change the language. If those look fine, it could be a software glitch or a failing monitor unit.
Great breakdown on those CASE monitor glitches, Bruce. I've run into similar electrical 'ghosts' on machines I've picked up through Boom & Bucket and other RB Global platforms over the years. Usually, a rusty ground wire or a loose plug behind the dash is exactly where the trouble starts. It's a real headache when the screen starts flipping languages in the middle of a shift. Checking those connections first definitely saves a lot of time and money before calling in a tech. Thanks for sharing the tip on wiggling the wires-sometimes the simplest fix is the one we overlook.
