What to look for when buying a used motor grader?
144
When buying used construction equipment, bring a qualified heavy equipment mechanic or equipment inspector if you're unsure. a thorough inspection can save thousands in unexpected repair costs.
if you're purchasing from a heavy equipment auction, always review inspection reports and understand the return policy.
I always recommend checking service records first. A well-maintained grader with higher hours is often a better buy than a low-hour machine with poor maintenance history. Also inspect tires, tandem drives, and transmission performance. If you're purchasing from a heavy equipment auction, review inspection reports carefully and make sure you understand the return policy before bidding.
When buying a used motor grader, check the overall condition, engine performance, and smooth hydraulic operation. Look for cracks, leaks, unusual noises, and review the service history and operating hours for peace of mind. Choosing reliable brands like Caterpillar or Komatsu can ensure strong performance and long-term value.
I'd focus more on overall condition than just the hour meter. Check for excessive play in the circle, moldboard, and articulation joint, as those repairs can be costly. Look for hydraulic leaks, worn tandem drives, and smooth transmission shifting. If possible, start it cold and take it for a short test run to see how it performs under load.
When buying a used motor grader, I'd focus on condition over brand first. Check the engine hours and service history - regular maintenance records are a big plus. Look closely at the articulation joint, circle gear, and moldboard for excessive play or wea rsince those repairs can get expensive fast.
Also inspect the transmission performance (smooth shifting), hydraulic system (no leaks, steady pressure), and tandem drives. Uneven tire wear can hint at alignment or frame issues. If possible, operate it under load to see how it handles.
Lastly, parts availability and dealer support in your area matter a lot - downtime can cost more than the machine itself.
When buying a used motor grader, I always check the blade condition, hydraulic system, and service history. A proper inspection helps avoid costly repairs later. Comparing prices on trusted platforms like Ritchie Bros. can also give a better idea of market value.
