What should you do if the start button on a CASE SV300 isn't flashing?
141
If the start button on your CASE SV300 isn't flashing and the machine won't start, it's usually something simple. First thing I'd check is the battery - low voltage or loose terminals can stop the system from powering up.
Also, make sure the seat bar is fully down, the parking brake is on, and the controls are in neutral. The machine won't allow starting if any safety switch is not detected. You can also take a quick look at the fuses and starter relay, and watch the display for any fault codes. Most of the time, it ends up being battery or safety switch related. Has anyone else run into this and found a different fix?
Yep, I’d also check the safety switches and wiring
those little things can stop it from starting real quick
