used bucket trucks
johnnyrogers
13
I am looking to purchase a used bucket truck, however, the issue that has presented itself is that the truck is both, in good condition and at a reasonable cost.
Has anyone acquired any recently? Any advice on which one should be more cognizant about?
Finding the right balance can be tricky! Check the hydraulic system and maintenance records because they're super important on bucket trucks.
Good point on the hydraulics!
I’d also say to check for rust, especially on the boom and undercarriage, it’s a dealbreaker for me.
Solid advice so far! I’d also take a close look at the wear on the pivot points and listen for any weird noises in the lift mechanism. A truck might look good on the surface, but if the boom’s got issues, repairs can get pricey fast. Anyone here ever had to rebuild a bucket truck’s hydraulic system?
Johny,
What I look for in a bucket truck is the year and manufacturer of the chassis and then the boom manufacturer. First, the chassis manufacturer has good and bad years of consistent engine issues. The Ford F-550 models from 2008 to 2010 offered two engine options: the 6.4L Power Stroke V8 diesel and the 6.8L Triton V10 gasoline engine. Of these, the 6.4L Power Stroke diesel is widely regarded as the less reliable choice due to a range of significant issues. Another is The International MaxxForce Engine Era from 2007 to 2010. These years coincide with the introduction of stricter EPA emissions standards, which led Navistar to implement the MaxxForce DT and MaxxForce 7 engines. The MaxxForce engines, particularly in 2007–2010 models, were widely criticized for reliability issues tied to their emissions control systems.
Then you have Boom manufacturers. My choice is usually with Altec, Manitec Elliott, or Versalift. Always look for worn hoses, cylinder leaks, and make sure that all functions are operational. If you want a reliable used bucket truck, check out our inventory at www.monsterequipmentinc.com.
I hope this helps.
Great advice! maintenance records can tell you a lot, and a clean hydraulic system is usually a good sign the truck was well cared for.
