Komatsu GD705-5 cranks but won't start.
Mc Wyndell
8
I'm having a no-start issue with my Komatsu GD705-5 grader. The engine cranks over normally, but it won't fire up and run. I've checked the batteries and basic connections, but haven't found the problem yet. Has anyone dealt with a GD705-5 that cranks but won't start? Any suggestions on what to check first, such as fuel delivery, shutoff solenoid, sensors, or electrical issues?
If the engine cranks normally, start with the basics: fuel, air, and electrical controls. A faulty fuel shutoff solenoid, clogged fuel filters, air in the fuel system, or a failed crank/cam sensor can all cause a no-start condition.
Check your fuel shutoff solenoid and fuel delivery pressure first—if it's cranking strong, it's usually a fueling issue.
I've run into similar crank-no-start issues before. I'd start by checking the fuel shutoff solenoid and making sure the fuel system isn't air-locked or restricted by a clogged filter. Those are common causes and usually easier to verify before digging into sensors or more complex electrical problems.
