How to put a track back on an excavator ?
pRinceAndrew
16
Hey folks, I’m dealing with a slipped track on my excavator and could use some advice. What’s the easiest and safest way to get it back on without causing more damage? Do you usually use a pry bar, grease gun, or another trick to get it seated right? Screenshot 2025-10-31 165533.webp
Photo for reference only
Ah, classic one that. Happens to the best of us, mate. A slipped track usually means you’ve hit a bit of uneven ground or had the tension set a touch loose. First thing, lift the side that’s slipped off just enough so the track can move freely. You can use your boom and blade to balance it, but make sure it’s stable before you start. Next, find the grease valve on the track adjuster and carefully let a bit of grease out. That’ll loosen the tension so you’ve got some play to work with.
Once it’s roughly in place, fire the machine up and slowly roll the track while someone keeps an eye on it. It should walk itself back on with a bit of patience. When it’s seated properly, pump the grease back in until there’s just a bit of sag in the middle. If it keeps slipping off, it might be worth checking your bottom rollers or sprocket wear. Sometimes that’s the real culprit.
You have to look for the missing bolts or defective rollers, and once done, locate the adjuster and grease fitting. Please make sure they are intact. Don't over-tighten the track because it sometimes causes premature wear.
