- 149
If you want to change the control pattern on a Cat 305E, you can usually do it through the machine's monitor / electronic module settings - no need to mess with hoses if the feature is enabled.
What you can try:
What you can try:
- Turn the key to the ON position (don't start the engine).
- Use the monitor panel buttons to go into the settings or service menu.
- Look for the "Control Pattern" or "Joystick Pattern" option
- Select your preferred pattern (ISO or SAE).
- Confirm and exit the menu, then restart the machine.
