How to Calculate Generator Load for Multiple Power Tools?
maxiMus000
14
hey folks I’m trying to size the right generator for a jobsite setup that be running multiple power tools at once.. think saws, drills, maybe a compressor. Ive seen some charts online but they all seem to vary, and I’m not sure how to factor in startup loads versus running watts. Do you calculate total load based on max usage or build in some buffer? Also, does anyone have a rule of thumb or formula that works well in the field? Would love to hear how you all plan your generator load for real-world conditions
good question
usually i total the running watts, add 50% buffer for startup surges, and round up
better to overshoot than trip the gen mid-cut
I usually add up all the running watts, tack on a solid buffer for startup surges, and size up-saves a lot of headaches on site.
I usually just add everything up and then go a size bigger than I think I'll need-better safe than tripping mid-job.
From my experience, I usually total the running watts, add around 40-50% buffer for startup surges, and go one size up..it saved me a few shutdowns on site
One tip that’s worked for me is to check the tool with the highest startup surge, especially compressors and larger saws, and size the generator around that, not just the total running watts. It gives you a little extra breathing room and helps avoid unexpected shutdowns on busy jobsites.
