How High Can You Go? Lift Height Limits Explained
BricklayerX
31
Hey folks, quick question about lift height limits on job sites.
  • What are the max heights you've worked with using boom lifts, scissor lifts, or telehandlers?
  • Are there general safety or legal limits in place, or does it vary by equipment and region?
I’m curious how high you can actually go before hitting restrictions or needing special permits. Would love to hear what others have experienced out in the field!
Hey, Most boom lifts cap out around 185 ft these days, while scissor lifts usually top off at about 50–60 ft depending on the model. Anything over 60 ft typically triggers stricter OSHA requirements and sometimes permits, especially if you’re working in certain regions or near power lines. Telehandlers are way lower and usually maxing around 55 ft. Curious if anyone’s pushed past those limits with specialty equipment?
Yeah, I’ve mostly worked within the 60 ft range too, and once you go higher, the safety checks and paperwork really kick in. Had to get a special permit once just to operate near a busy downtown area. Definitely not something you want to wing without checking local regs first!
From my experience, most lifts top out around those heights you mentioned. Definitely agree that once you hit the 60 ft mark, the safety hoops and permits start to multiply fast. Better to be safe and double-check local rules before pushing any limits, especially near power lines or crowded spots. Anyone here worked with specialty lifts that go even higher? Would love to hear!
Yeah, once you’re up past 60 ft, it’s a whole different ballgame with permits and safety protocols. I’ve mostly used boom lifts around 80–135 ft, and anything taller usually needed a site-specific plan and clearance near utilities. Always worth checking the regs ahead, no one wants surprise red tape mid-job!
