Has anyone replaced an F5BFL413C with an F5BFL413A in a Case 580N?
32
I'm replacing the engine in a 2016 Case 580N backhoe. Can the F5BFL413A replace the F5BFL413C? If you've done this swap, what parts need to be changed? Thanks!
hey, I haven't done that exact swap myself, but I'd definitely compare the engine serial numbers, wiring harness connections, ECU setup, and any emissions-related components before bolting everything together. Sometimes the engine will physically fit, but sensors or electronics can be different between suffix versions. A good tip is to cross-reference both engine part numbers with a Case dealer or parts catalog first. Has anyone here done the A-to-C or C-to-A swap and run into wiring or calibration issues?
