Best Practices for Efficient Asphalt Removal?
Jackross
13
Hey folks, let's dive into cold planers. What techniques have you found to optimize asphalt removal while minimizing wear on the equipment?
Keeping your teeth sharp and replacing them regularly makes a huge difference, and running at the right depth helps avoid unnecessary strain on the machine. Anyone have a go-to cold planer brand they swear by?
Good call on the teeth—dull ones just slow you down and burn more fuel. I’ve also found that keeping a steady speed and not forcing the cut too deep helps with efficiency. Wirtgen’s been solid for me, but I know some guys swear by CAT. What’s been working best for you?
Totally agree! Sharp teeth and steady speed make all the difference. Also, keeping an eye on water flow helps with cooling and dust control. Anyone have tips for dealing with stubborn patches that just don’t want to mill cleanly?
I’ve found that using a consistent pattern when milling helps with those stubborn patches. Sometimes, slowing down a bit on the tough spots or adjusting the depth slightly can make a big difference too! What’s your strategy for handling those tricky areas?
Totally with you all! sharp teeth, proper water flow, and a steady pace are key. For stubborn spots, I usually tighten the cut pattern and drop the depth just a hair, which makes a big difference without stressing the planer too much!
