Hydraulic Hose Leaks and Failures, How to Prevent Downtime?
Butch232
25
Hey everyone, I’ve been dealing with a few hydraulic hose leaks lately and it’s starting to cause some downtime on the jobsite. What are your go-to practices for preventing hose failures before they happen? Do you rely more on routine inspections, scheduled replacements, or upgrading hose quality? Also curious if certain fittings or routing setups have made a big difference for you. Any tips or lessons learned would be really helpful!
What's worked best for me is doing quick routine inspections and fixing small wear before it turns into a burst hose. I always check for rubbing, cracks, loose fittings, or oil sweating at the crimps. Proper routing and clamping also makes a big difference, especially on boom or bucket lines that move a lot.
Hose leaks are the absolute worst-it's usually a $50 part that ends up costing you $500 in lost time and spilled fluid.
When a hose blows, you aren't just losing fluid; you're losing hourly production and potentially risking the pump if the system runs dry.
From my experience, the best way to prevent hydraulic hose failures is to stay ahead of them. I do a quick daily inspection to catch any leaks, cracks, or rubbing early. Proper routing makes a big difference-keep hoses away from sharp edges, heat sources, and moving parts, and make sure they have enough slack so they're not under tension. I also don't wait for a hose to fail; if it starts looking worn or weak, I replace it right away. Using good quality hoses and proper fittings is worth it too, because cheap parts usually fail faster. Most issues I've seen come from abrasion and heat, not pressure, so if you control those, you'll cut down a lot of downtime.
Had the same thing happen on a skid steer last year, one hose kept rubbing on the frame just enough to fail every few months until we rerouted and sleeved it.
