What diesel generators do you guys recommend around 6000W? Anyone running a light tower generator?
USVeteran
121
I'm starting to look at diesel generators in the 6000W range and wanted to see what people here are running. I'm mainly looking for something simple, reliable, and fuel-efficient, preferably an 1800 RPM unit since it will likely run quite a bit.
I've seen quite a few people recommend Kubota diesel units around that range. They seem pretty reliable and fuel efficient, especially the 1800 RPM models. A used light tower generator with a Kubota engine might also be worth checking out.
Finding a solid 6000W diesel is a smart move, especially if you're looking at long run times. Most people in this range swear by a Yanmar or a Kubota engine. They're basically the gold standard for small diesels because parts are everywhere and they're built like tanks.
I’ve had good luck with Kubota-powered light towers, its simple, sips fuel, and they’ll just keep running as long as you keep up with basic maintenance
If you're planning to run it a lot, I definitely think you're on the right track looking for an 1800 RPM diesel unit.
