Could a leaking master cylinder be causing transmission overfill and brake failure on a Komatsu WA320-1?
George
125
When I got the machine, transmission oil was leaking out of the vent, and I found it about 5 gallons overfull. The previous owner mentioned the brakes needed to be pumped to work, and now I'm seeing the same thing- it takes around 10-15 pumps, and the brake fluid reservoir ends up empty. Here's the strange part: I can't find any external leaks anywhere. From what I've been reading, it sounds like it could be a leaking brake master cylinder dumping fluid into the transmission over time. Does that sound like a likely cause on these machines?
If that's the case:
  • Is rebuilding the master cylinder usually enough?
  • Or should I be checking other components (like seals, brake valves, or lines into the trans)?
  • Anything specific to watch out for on the WA320-1?
I'm planning to use this for a home project on a hill, so I definitely need the brakes 100% reliable before putting it to work. Appreciate any insight.
Most likely culprit is the brake master cylinder (or internal seals) leaking internally and slowly dumping fluid into the trans over time.
