What’s the reason a wheeled backhoe is nicknamed a ‘rubber duck’?
Mr. McTuggart
136
Hey everyone, I've been digging into different types of backhoes, and I keep seeing people call a wheeled backhoe a 'rubber duck.' I get that it's probably because of the tires, but I'm curious-why exactly is it called that? Is it just a nickname in the construction world, or is there a deeper reason behind it? Also, are there differences in usage or performance between a rubber duck and a standard tracked backhoe that I should know about?"
The nickname "Rubber Duck" is almost exclusively used for wheeled 360-degree excavators, rather than the standard tractor-style backhoe loaders (like a JCB 3CX).
It comes from the rubber tires instead of steel tracks. Back in the day, most excavators were tracked, so when wheeled versions started showing up, operators needed an easy way to tell them apart.
The nickname “rubber duck” for a wheeled backhoe mostly comes from its rubber tires instead of steel tracks. Compared to crawler machines, it can move faster and looks a bit more “light and bouncy,” so operators started calling it that in a fun way.
Another reason is how smoothly it drives on roads and job sites, almost like it’s gliding, which adds to that “duck” feel.
You’ll see a lot of these machines listed on platforms like Boom and Bucket, where contractors like them for versatility and easy transport. Other RB Global brands like Ritchie Bros. and IronPlanet also show how popular wheeled backhoes are because they’re practical for mixed job sites.
Simple name, but it really fits how the machine behaves 👍
It’s called a “rubber duck” because of the rubber tires instead of tracks—simple as that. They’re faster and better for roads, while tracked machines handle rough terrain better.
If you’re comparing options, Boom & Bucket is a great place to check—easy to browse and they’ve got reliable equipment listings.
