IamBruce_Driver
Active member
- Messages
- 142
When your CASE monitor starts acting up, flipping screens or switching to Japanese, it's usually a "communication" problem, not a ghost. Think of it like a loose phone charger; when the connection blinks, the system resets to its original factory settings.
Here's what to check:
- Loose Plugs: Wiggle the wires behind the screen. If the plug is loose or dirty, the monitor loses its "memory" and resets.
- Bad Grounds: A rusty or loose ground wire is the #1 cause of electronic glitches. Make sure the metal-to-metal connections are clean and tight.
- Battery Power: If your battery or alternator is weak, the screen might not get enough juice to stay on the right setting.
