Which buckets fit a Cat 334D excavator without X-Change?
George
141
I recently bought a Cat 334D excavator without the X-Change system. I'll be changing buckets manually, but I'm not sure which bucket types or brands are compatible. Any recommendations?
I’d check the pin diameter, ear spacing, and linkage dimensions first, since a bucket can look like it fits but still be a mismatch.
I’d probably start by looking at used pin-on buckets since you won’t be using the X-Change system. There should be a few options out there, but make sure the pin size, spacing, and ear width match your 334D before spending money. It’s worth taking a few measurements first so you don’t end up buying a bucket that almost fits but still needs extra work.
