What are the small loaders called?
jameOliver
17
Hey everyone, I often see compact loaders being used in tight spaces—what are these small loaders called? Are there different types depending on the job?
I’ve found CTLs to be a game-changer when it comes to handling tough terrains—much better traction and less ground disturbance compared to wheel loaders. Plus, they’re way more stable when moving heavy loads on soft or muddy ground! Anyone here use them for snow removal or landscaping too? Curious about how they perform in those scenarios.
Those small loaders you’re seeing are usually called skid steers or compact track loaders (CTLs)—skid steers have wheels, CTLs run on tracks. Skids are nimble and great on hard surfaces, while CTLs shine on soft or uneven ground. There’s also mini wheel loaders, which are more common in ag or light construction. Depends on the job, but each has its sweet spot! What kind of work are you looking to use one for?
Yeah, those small loaders are usually called skid steers or compact track loaders (CTLs). Skid steers are great for hard surfaces, while CTLs do better on soft or uneven ground. Mini wheel loaders are another option if you need something for lighter jobs. It really depends on what kind of work you’re doing. What’s your main use for one?
They’re mostly called skid steers or compact track loaders, that super handy in tight spots! If you’re working on softer ground, CTLs are the way to go. Curious if you're using it for landscaping, small demo work, or something else?
