- 98
I'm currently dealing with an error warning showing on the monitor of my Liebherr HS 853 HD duty cycle crawler crane, and I'm trying to figure out the best way to fix it before calling for service.
From what I understand, error messages on the Liebherr HS 853 HD display panel can be caused by several things such as sensor faults, hydraulic system warnings, electrical connection issues, or low fluid levels. Sometimes it can also be related to safety systems or load monitoring functions that need to be reset or recalibrated.
So far, I'm planning to check the machine's battery voltage, wiring connections, hydraulic oil level, and any visible loose plugs or damaged sensors. Restarting the machine and reviewing the operator's manual for specific Liebherr HS 853 HD error codes might also help narrow down the cause.
If anyone here has experienced a Liebherr HS 853 HD warning message or screen error, what was the actual fix in your case? Was it something simple like a reset or sensor replacement, or did it require dealer diagnostics?
