Is It Worth It? Stihl MS290 for $275
Rigroller
31
Hey guys,
I found a Stihl MS290 on Craigslist for $275. I’m planning to use it for cutting about 8-10 cords of mixed hardwood per year (mostly maple and oak). Is this a good deal, or should I keep looking?
Thanks in advance for any thoughts or advice!
Hey Rigroller,
That sounds like a pretty solid deal if the saw is in good condition! The Stihl MS290 is a reliable mid-range saw, and for the amount of cutting you're planning, it should handle the job without too much trouble. It’s got enough power for hardwoods like maple and oak, and at $275, you're getting good value, especially if it’s been well-maintained.
One thing to check is the overall condition and make sure the bar, chain, and engine are in decent shape. If it runs smoothly and doesn’t have too many hours on it, I’d say go for it! But if you're unsure, maybe try running it a bit first or ask for more details from the seller.
How’s the saw look in terms of wear and tear?
Agreed—$275 is a pretty fair price if it’s in good shape. The MS290 is a solid workhorse and should handle 8-10 cords of hardwood just fine. Like Albert78 said, check the bar, chain, and compression before pulling the trigger. If it fires up easy and isn’t too beat up, I’d say it’s worth it. Worst case, you might need a little maintenance, but even then, it’s still a decent deal. Did the seller mention anything about maintenance history?
Sounds like a solid deal if it’s in good shape! The MS290 is a tough saw, and for 8-10 cords a year, it should hold up fine. Just make sure to check compression, bar/chain wear, and if it’s been maintained well. Did the seller say anything about its history?
Hey @Rigroller, that price seems pretty fair for the MS290, as long as it's in good condition. It’s a solid saw that should handle the 8-10 cords of hardwood you’re cutting without issues. Just be sure to check the overall condition, especially the bar, chain, and engine and if it runs smoothly, I’d say go for it!
Sounds like a fair deal if the saw is in good shape! The MS290 is a reliable workhorse, especially for hardwoods. Just check compression, bar, and chain wear before pulling the trigger, if it runs smooth, it should serve you well!
