Generator Troubleshooting: What’s the First Thing You Check When It Won’t Start?
48
Ran into an issue recently where a generator wouldn’t start, and it got me thinking.. what’s your go-to troubleshooting process when a genset acts up?
In my case, the unit had power but wouldn’t crank. Checked the basics first:
  • Battery voltage (looked okay at first glance)
  • Fuel level and lines
  • Air filter condition
Turned out to be a weak battery under load, not obvious until tested properly.
Made me realize how easy it is to overlook simple things before diving deeper.
For those of you working with generators regularly, especially on job sites or rentals:
-What’s the first thing you check?
-Any common issues you see over and over?
-Ever had a “simple fix” that turned into something bigger (or vice versa)?
Also curious if anyone has a solid checklist they follow in the field, trying to tighten up my troubleshooting workflow.
Would be great to hear your experiences.
For me, I always start with the battery and connections, no matter what. I've had too many cases where everything "looked fine" until you actually load-tested it. Also check grounds-loose or dirty grounds have caused more no-start issues than people think.
Honestly, batteries are probably the #1 culprit more often than people think A battery can look "fine" voltage-wise and still completely fall on its face under load.
I'd add checking the emergency stop switch too. I've seen a few no-starts that turned out to be nothing more than an accidentally engaged E-stop.
