Need help fixing an error warning on my Liebherr HS 853 HD monitor.
James R.
140
I'm currently dealing with an error warning showing on the monitor of my Liebherr HS 853 HD duty cycle crawler crane, and I'm trying to figure out the best way to fix it before calling for service.
From what I understand, error messages on the Liebherr HS 853 HD display panel can be caused by several things such as sensor faults, hydraulic system warnings, electrical connection issues, or low fluid levels. Sometimes it can also be related to safety systems or load monitoring functions that need to be reset or recalibrated.
So far, I'm planning to check the machine's battery voltage, wiring connections, hydraulic oil level, and any visible loose plugs or damaged sensors. Restarting the machine and reviewing the operator's manual for specific Liebherr HS 853 HD error codes might also help narrow down the cause.
If anyone here has experienced a Liebherr HS 853 HD warning message or screen error, what was the actual fix in your case? Was it something simple like a reset or sensor replacement, or did it require dealer diagnostics?
Good move trying to troubleshoot it first. A lot of Liebherr HS 853 HD monitor warnings turn out to be something minor once you start checking the basics.
Here's a quick checklist to try before you get too deep into it:
  1. Try a "Cold Boot": Kill the engine, flip the battery disconnect switch for about 5 minutes, and then restart. It's the classic "turn it off and back on again" trick that clears out those annoying glitchy logic errors.
  2. Give the Plugs a Look: Check those gray or black Deutsch connectors sitting near the valves. If a locking tab has snapped off, the pin might just be wiggling around and losing contact.
  3. Check the Code: Is the monitor throwing a specific 3 or 4-digit number at you (something like "E104")
