Why won't my Yale GLP030 forklift start after cleaning the distributor cap and rotor?
Tammy Gebbins
17
My Yale GLP030 was running rough on cold starts, so I cleaned some corrosion from the distributor cap and rotor. After putting everything back together, it now cranks but won't start and occasionally backfires.
I'm wondering if I may have mixed up a plug wire or have the firing order wrong. I believe the engine is a Mazda 2.0L/2.2L with a 4-3-1-2 firing order. Any ideas on what I should check first?
double-check that every plug wire is back in the correct firing order and fully seated, If it started acting up right after the distributor work.
A quick look to make sure the distributor cap is installed correctly and the rotor is lined up properly can save a lot of troubleshooting.
