What's the difference between movement solenoids, injector solenoids, and the engine shutoff solenoid on a Cat 140H?
Jayne_Monie
16
I'm working on a Cat 140H grader and need some clarification. Can anyone explain the difference between the movement solenoids and the injector solenoids? Also, is the engine shutoff solenoid the same as one of the movement solenoids, or is it a completely separate component? Any help would be appreciated.
They're all solenoids, but they do different jobs.
The movement solenoids are usually part of the hydraulic or transmission control system. They direct oil flow to operate functions like steering, blade controls, or gear shifting, depending on the machine's configuration
