Why does the head gasket keep blowing on a Komatsu WB140-2N with a Yanmar S4D106 engine?
Robert M.
56
I'm working on a Komatsu WB140-2N with a Yanmar S4D106-1FH engine, and I'm completely stuck on a head gasket problem. The machine runs and drives great, but after a few hours of use, the head gasket blows again - always on the same 3 cylinders. Has anyone here dealt with repeated head gasket failure on a Yanmar S4D106 engine before? I'm trying to figure out what could keep causing the same cylinders to fail even after all the machine work.
If it's always blowing on the same cylinders, I'd start looking for a warped head, liner height issues, or a crack in the block or head. Repeated failures in the same spot usually point to an underlying mechanical problem, not just a bad gasket.
