Troubleshooting the GEHL RS8-44 hydraulic priority valve issue.
James R.
132
On a Gehl RS8-44 with a tri-function joystick and PWP, feathering the brake while moving can make the joystick lose pressure. It only returns when the brake is fully released or the machine stops. The declutch switch doesn't help, even with the wireless remote.
Likely causes: priority valve issue or brake/joystick hydraulic interaction. Checking the priority/relief valves and testing pressure under braking usually helps pinpoint the problem.
Sounds like you’re on the right track. I’d probably check the priority valve for sticking or contamination first, then run a pressure test while feathering the brake to see if it’s starving the joystick circuit
