Frank Zimmerman
- Messages
- 43
I'm having a transmission issue with my Volvo A35C articulated dump truck. In low range, it shifts through all the gears
If your Volvo A35C shifts through all gears in low range but has problems in high range, I’d start by checking the transmission control system, range selector, and related wiring or solenoids. Also, check the transmission oil level and condition, along with any fault codes. Does it refuse to shift into high range completely, or does it engage but slip or lose power? That detail will help narrow down the likely cause.If your Volvo A35C won’t shift into high range, I’d start with the simple things before suspecting a major transmission problem. Check the transmission oil level and condition, then inspect the high/low range switch, wiring, connectors, and fuses for any loose or damaged connections.
It’s also worth checking whether there are any active fault codes, because an electrical or transmission-control fault can prevent high range from engaging. If low range works normally but high range doesn’t engage at all, the range-control solenoid or its electrical supply would be one of the areas I’d test.
A pressure test at the transmission/range circuit can help confirm whether the problem is hydraulic or electrical rather than replacing parts by guesswork. Also check whether the machine is actually receiving the command to select high range.
바쁜 일상 속에서 쌓인 피로를 풀고 편안한 휴식을 즐기고 싶습니다. 요즘 집에서도 편하게 이용할 수 있는 다양한 마사지 서비스를 알아보고 있습니다. 서울출장마사지 서비스를 통해 편리하고 만족스러운 힐링 시간을 경험해 보고 싶습니다. 예약하기 전에는 업체의 신뢰도와 전문성, 이용 후기를 꼼꼼하게 확인하는 것이 중요합니다. 합리적인 가격과 친절한 서비스를 제공하는 곳이라면 더욱 좋을 것 같습니다. 실제로 이용해 보신 분들의 추천이나 경험담이 있다면 공유 부탁드립니다!
