Scissor Lifts vs. Boom Lifts – Which One Should You Choose?
ArchTech
20
Hey everyone! I’m trying to decide between renting a scissor lift or a boom lift for an upcoming project, and I’m not sure which one makes more sense. What are the key differences in performance, reach, and safety, and how do you choose the right lift for different job types? Would love to hear what’s worked for you!
Hey @ArchTech, I’ve used both depending on the job, if you're working straight up on flat ground, scissor lifts are great. But for anything that needs reach or maneuvering around obstacles, boom lifts are a lifesaver. What kind of work are you doing in indoor, outdoor, or something with tight access?
Totally depends on the job, coz scissor lifts are solid for vertical work on stable surfaces, but boom lifts give you way more horizontal reach and flexibility, especially outdoors or over obstacles. If you're dealing with tight spots or elevation shifts, boom’s the way to go.
I’d go with a boom lift if there’s any chance you’ll need to reach over obstacles it saved me big time on an exterior install last month where a scissor just wouldn’t cut it. What kind of site are you working on?
if it’s mostly straight-up work on stable ground, a scissor lift does the job efficiently. What kind of space are you working in?
