Working Around Power Lines - How Do You Stay Safe in the Bucket?
Big_Iron
Administrator
Staff member
61
Hey everyone, I wanted to start a discussion about working safely around power lines while operating in a bucket. How do you guys handle proximity hazards or unexpected line movement on windy days? Do you follow specific clearance rules or use certain tools or gear for extra protection? I've heard mixed advice about grounding and insulating equipment, so I'm curious what's actually worked for you in real job settings. Any tips or close calls you've learned from would be great to hear!
i always double-check my clearance before moving the boom and keep an eye on wind shifts - those lines can surprise you fast.
a good rule i stick to: If i think it's too close, it probably is!
i'm with you on that ..slow movements, extra clearance,a nd treating every line like it's live has saved me more than once
100% agree with the "if it feels too close, it is" rule. I always treat every line like it's live, move slow, and keep extra clearance especially when the wind starts shifting. If I'm working anywhere near lines, I also try to plan my boom movements before I even leave the ground so I'm not making last-second adjustments up in the bucket. Better to take an extra minute than get surprised.
Hey, great topic-safety first around power lines! I always stick to OSHA's minimum approach distances: at least 10 feet from lines up to 50kV, scaling up for higher voltages.502b6e On windy days, I add extra buffer (like 5-10 more feet) and use spotters to watch for sway. Insulated booms and tools are key, plus full PPE like rubber gloves and dielectric boots. Grounding the truck helps in some setups, but never assume-treat all lines as live. Had a close call once with unexpected gusts; now I always check weather apps beforehand. Stay safe out there!
Planning your boom movements before leaving the ground is a great habit. It definitely helps avoid rushed decisions when you're up in the bucket
