What Should You Do If Your Excavator's AC System Is Leaking?
122
An excavator AC leak will kill the cooling fast. Don't just recharge it.
Signs
  • Weak or warm air
  • AC stops cooling quickly
  • Oil residue on hoses/fittings
Quick Fix Steps
  1. Find the leak (visual check or UV dye)
  2. Repair/replace damaged hoses, seals, or fittings
  3. Vacuum the system
  4. Recharge with the correct refrigerant
  5. Test cooling performance
Always fix the leak first; recharging alone is a temporary fix. Locate repair recharge. That's the only long-term solution.
Good advice overall—especially the point about not just recharging and actually fixing the leak first. I’d also add that checking the compressor and condenser condition can help, since a leak sometimes leads to extra strain on those components. In dusty job site conditions, clogged filters or fins can make the issue seem worse than it is. Taking a few extra minutes to inspect the full system can save bigger repair costs later.
If your excavator’s AC system is leaking, the first thing you should do is identify the source of the leak. Most leaks come from hoses, fittings, or the condenser. Look for oily residue around connections, as that’s a common sign of refrigerant leakage.
Next, stop using the AC system to prevent further damage. Running it with low refrigerant can harm the compressor, which is expensive to repair.
After that, it’s best to have the system pressure-tested. A technician can use dye or specialized tools to pinpoint the exact leak. Once found, repair or replace the damaged component like a hose or seal.
Finally, recharge the system with the correct refrigerant and check if it’s cooling properly again. Regular maintenance, like cleaning the condenser and checking hoses, can help prevent future leaks.
I’ve run into this on a couple older machines over the years. It’s almost never just a simple recharge like people hope. There’s usually a small leak that needs to be tracked down first. Learned that the hard way after wasting time and money. Good, straightforward advice here.
Good advice—especially the reminder not to just recharge. Fixing the leak first is key to avoiding repeat failures and bigger repair costs later.
